Discuss noisy main 18 he heat only boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammerheat
Hi guys,
Got a customer with the above boiler that makes a loud noise on start up then stops. this happens intermittently, any come across this?
What sort of noise is it
Banging
Metal on metal
Clicking etc
Have you tried contacting the manufacturer? They should know what it’s causing the noise.
Check the fan
Reply to noisy main 18 he heat only boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
