Discuss noisy radiators- water running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Seng84
Yesterday I took off a radiator in the kitchen to allow a fridge to be installed
the radiator is going to have to stay off for a day or two now until I get the fridge doors reversed.
in the mean time the radiator in the bathroom (next to the kitchen) is making a loud running water noise that has only stopped when the heating is turned off
i have recently bled all the radiators with the exception of this one as I didn't have a key that fit.
any ideas?!
thanks
Sounds like in taking the radiator off some air has entered the system. Downstairs is often on a separate, dropped loop from the upstairs radiator. You'd need to bleed it and see. If it's for a short while it shouldn't matter too much if a little air starts to circulate through the system. You can bleed it out later
Reply to noisy radiators- water running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
