Discuss Noisy TRV in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
craigy
I have a noisy TRV on one rad only which is the only TRV to be changed in the bungalow. New combi fitted to old 2 pipe system. Most of the TRVs are fitted to the returns as they were when first installed, the kitchen is the only rad to have the TRV fitted to the flow. The noise is coming from a living room rad which has been replaced with the TRV on return. Have bled and balance the system, the TRV is bi-directional. Only bangs when cooling or on setting 2-3. Changed TRV no difference.
Any ideas?
Is the arrow on the bi-directional valve facing the right way? This would be pointing away from the rad if it is on the return.
It's BI directional!!!
Was that a serious question?
Yes it was as on a bi-directional valve you need to adjust the arrow on the valve so that the arrow is running with the flow
Bi directional valves can go either way. Hence the name bi
Older valves could only go one way.
Have a look at a bi directional valve and you will see an arrow pointing both ways
yes i know how a bi-directional works but you still need to ensure that the adjustable arrow is going the right way this is my point ( danfoss )
scotty is right the danfos brand have a arrow that needs to be pointed the right way,however most bi valves can be fitted either way with no adjustment to the OP if the trv has been replaced try opening the locksheild valve slightly see if this helps if not try swapping to a different make trv
What's the point in it being bi directional if you have to fit it in the right direction?
theres a arrow on the head of the danfos you just turn by hand when fitted it supposedly eliminates this problem,even though all bi valves should do what they say on the box every now and then you will get some that dont
Reply to Noisy TRV in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
