Discuss O ring replacement or thread seal? in the Plumbing Tools area at PlumbersForums.net
Yep watch his tool reviews well disassembly
It's a shame he's not really doing the power tool reviews any more and has retired to the country. Good luck to him anyway.
Do you know his story, can't work out exactly what he does or his specialism if he has one. He has or had a shop (machine) I take it.
Knows about tooling and tools, some electrical/electronics, CNC machining and hydraulics and cranes apparently. I've only watched a few but was drawn initially to the tool review stuff.
I recon it’s mod or power company fault fixer :D / there equivalent
Reply to O ring replacement or thread seal? in the Plumbing Tools area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
