Discuss Odour from internal manhole cover - how to seal? in the USA area at PlumbersForums.net
I've an internal manhole cover in my garage, covering the main waste drains. Only moved into the house about 6 weeks ago but noticed it occasionally smells a bit cabbagey around the area of the cover.
Have lifted, checked for blockage and cleaned out somewhat but still get a bit of smell now and then. Looking at the cover, it looks like the seal might be past its best, so I was thinking of applying a good layer of manhole grease around the edges but wanted to see if anyone had any better suggestions?
Thanks,
Ben
Thanks RPM, do I need manhole grease or could I use some alternative from Screwfix etc. that's available in a smaller quantity? (ideally don't want to spend £35 on a 3kg tub of grease)
Well, going by another post on the same subject somewhere else recently a respected poster said even Vaseline would do, of course any nicks in the seal and it wont seal properly.
Understood. I might remove the old rubber seal and replace with something similar before applying grease. At the moment, the old seal has gaps in it. This might be a dumb question but does it matter what shape the seal is, as long as it fits into the groves? E.g. this Stormguard EPDM Rubber P Strip White 20m - https://www.NoLinkingToThis/p/stormguard-epdm-rubber-p-strip-white-20m/33145#product_additional_details_container looks different from the seal that's currently in there but not sure if I can find an exact like for like
Reply to Odour from internal manhole cover - how to seal? in the USA area at PlumbersForums.net
Hi I moved house about 9 months ago. Around 3 months after moving in I started to notice an intermittent sewage smell in the bathroom upstairs...
9K
Hi all, new here so I hope I'm posting in the right place. I'm having a hell of a time with my bath drain cover. I just wanted to take it off to...
5K
Hi, Need some advice about a soil pipe in 1966ish built ex-mod property. We have suspected but not be able to prove that since some heavy...
16K
Hi all. I noticed today that some stains have appeared on my downstairs hall ceiling, just beneath the en-suite - there is a large sort of...
2K
H
  • Locked
Hi all I am new to the forum and really looking for some help - I am not a plumber nor an experienced DIY-er. We moved into our new house a...
10K
glasgowplumber
G
