Discuss Oil burner comes on when timer is in standby in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jonnystewart
I have noticed that when my heating timer is in standby - that the oil burner still comes on. It burns but does not heat the house.
Could the issue be due to a motorized valve issue?
In my heating system there are 3 motorized valves (sunvic) - I take it one if for heating downstairs, one for upstairs and one for hot water.
All help is appreciated.
Jonathan
Could well be a stuck microswitch in one of the valve heads, Sunvic are not one of my favourite makes. Time to get the electrical test gear out.
Thanks Simon,
Out of interest - these are 2 port valves - is it just a matter of removing the top of the valve and using a volt meter to test.
If it was a microswitch problem - is it a complete new valve I would need or just a part?
What make of valve would you suggest.
Jonathan
I would test in wiring centre to see which one is giving you a live supply.
Personally I would replace the head, others on here are a bit more techy on these things and could advise further.
I like honeywell, have a lot less issues than Sunvic, Horstman, Danfoss etc. But if the valve is fine just drop a new head on.
If it is not the microswitch it is more likely to be the synchron motor stuck in the open position leaving the microswitch activated, the gears in the motor usually jam and stick open. You can replace the motor but you would be better off changing the head assimong says.
Reply to Oil burner comes on when timer is in standby in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
Hi folks, hoping someone can help with a problem that's been perplexing me since just before Christmas..... I have a wet underfloor heating system...
1K
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
M
Hi, Hopefully someone can throw some light on if this is a real issue or not. I have had this boiler for about 10 years, I noticed just recently...
R
Hello its my 1st post hope im in the right place We brought a new house a medium-large 3 bedroom semi, we moved in the summer. Now coming to...
