Discuss oil burner problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
desiboy
Dont have much to do with oil Can anyone help ? WB oil fired combi no oil to nozzel and no ignition, oil to pump, pump pressure ok, pump filter clean, new nozzel.
How old is the boiler? What type of burner? Did you have to put the oil gauge directly into oil pump or into little tapping before it enters the nozzle?
If it's directly into the pump then it's probably the coil as dkia said.
Reply to oil burner problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
