Discuss Oil Central Heating Switch in the DIY Plumbing Forum area at PlumbersForums.net
I have an oil heating system, and also I have an open coal fire , the coal fire also heats the water through a back boiler and a neutralising tank , when the coal fire is on the water starts boiling, the only way i can stop it is to put the oil central heating on to circulate the water, is their any way i can run the circulating pump without having to put the boiler on. Could i fit an override switch so that I can turn the circulating pump on when the water starts boiling, is their any problems in doing this?
Reply to Oil Central Heating Switch in the DIY Plumbing Forum area at PlumbersForums.net
