Discuss Oil fired aga combined feed and vent in the Central Heating Forum area at PlumbersForums.net
exedon2
Re-boilering large property found existing 45kw oil boiler and oil aga shares same feed tank
Aga is on a combined feed and vent
My inclination is to change it thoughts?
I was under the impression combined feed and vents were only acceptable on appliances with thermostatic control and latching over heat stats which a vapourising burner doesn't have
For piece of mind I would redo.
Edit: I'm going to check with an associate for you.
Reply to Oil fired aga combined feed and vent in the Central Heating Forum area at PlumbersForums.net
