Discuss oil flow rate measurement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jjclancaster
Hi folks, wondering what people use to measure oil flow can't find any manual measuring equipment?
I realise it's for measuring flow but why do you need that ?
I'm only curious because I have worked on oil for a long time and never needed one.
are you asking just so you can fill in that space in the form ?
I usually just look at the MI's, the info is often in that table with the nozzle and CO2 readings etc, it will have an oil flow rate for each pressure/nozzle setup.
Reply to oil flow rate measurement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
