Discuss oil Pressure Guage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
cbs
I have bought a glycerine filled pressure gauge I wish to use it for setting the pressure on oil burners. Does anyone know what type of fitting I would need to use on the end of the tube to attach it to the burner. As I dont want to buy an expensive commissioning kit.
attend an oil training course and youll find out!!!!!!!!!!!
Personally I wouldnt try that without the kit, the manifold itself is very useful for bleeding oil lines and gets rid of the air in the flexible hose to the guage. This is not something you want to start DIYing and if you are competent, wait for experience to set in before cutting those sorts of corners.
think its diy, probably no smoke pump or fga either so one sooty boiler, buckled baffles or much worse to follow
And a manifold is ÂŁ15, not expensive anyway, think the kit is only ÂŁ45..
may be a daft question but what training did you do where you have to ask what hose fitting do I use!!!!!!!!!!!!!!!!!
Im not from a plumbing background so I dont no the names or fittings. that not the whole point of a forum to share knowledge? Bought a manifold for my pressure gauge yesterday.
Also I do have a smoke pump and a fga
Well, a forum is like a virtual pub where its all types of subject related chat, not just dishing out free advice. We have to be very careful as many many people join every day to ask advice on how to solve problems themselves and unless the 'asker' has told us his experience and or qualifications, how are we to assume their competency? Easy and safest way is to presume there isnt any which is why many posts are answered swiftly with 'Get a plumber..." etc.
Your post started with what you had bought and that you wanted to cut corners, your profile offers no background. So a wary response is understandable.
1/4" iirc personally I have always used a brass extension off a old burner.
as he's new he wont have one of those available yet. If your not fm a plumbing background, are you just starting by working on oil appliances as a servicing and commissioning technician, which Id consider quite brave of you, but good luck and I expect youll be on here regularly.
Reply to oil Pressure Guage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
