Discuss Oil regulators on suspended oil heaters in the Oil and Solid Fuel Forum area at PlumbersForums.net
Im working on 6 suspended air blowers running old riello G5s.Oil tank is 100m away on
ground level so 5m lower than the burners.So each unit has a Tigerloop which are all supplied with half inch iron pipework. Each unit has isolating valve 3\8 regulator oil filter then tigerloop. Can anyone explain why the regulators are necessary?
i understand regulation is necessary if oil tank position is high creating a lot of head but dont understand the above.
look forward to your replies. Ian.
It’s pumped / on a lifter station hence the regs
Reply to Oil regulators on suspended oil heaters in the Oil and Solid Fuel Forum area at PlumbersForums.net
