Discuss Oil regulators on suspended oil heaters in the Oil and Solid Fuel Forum area at PlumbersForums.net
Im working on 6 suspended air blowers running old riello G5s.Oil tank is 100m away on
ground level so 5m lower than the burners.So each unit has a Tigerloop which are all supplied with half inch iron pipework. Each unit has isolating valve 3\8 regulator oil filter then tigerloop. Can anyone explain why the regulators are necessary?
i understand regulation is necessary if oil tank position is high creating a lot of head but dont understand the above.
look forward to your replies. Ian.
It’s pumped / on a lifter station hence the regs
Reply to Oil regulators on suspended oil heaters in the Oil and Solid Fuel Forum area at PlumbersForums.net
I’m replacing my single skin plastic oil tank with a new bunded oil tank. I’m going to replace the single 10mm pvc covered oil pipe too, so to...
Hi, sorry this is so long. I have tried to give all relevant info. We are building a new, small, two-storey house that is off grid for power...
Hi all, I just joined the forum as I couldn't find help just being a lurker. :) I just bought my first house (yay me) and it's a new one. The...
7K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
Hi All, I am so glad I found this forum whilst looking for advice on the net. I am not a plumber as such but I do know a thing or two about DIY...
6K
