Discuss old school type radiator..fittings sizes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
steve6710
am i likely to encounter any issues fitting new tails to an old reclaimed school radiator.
is it going to be an imperial to metric situation?
thanks..
3/4 most likely.
use 22mmx3/4 rad valve if pipe is 22mm. If its 15mm then u can get 3/4 to 1/2 rad tail reducers
Use a heating engineer, a real one will know what to do
That's not very helpful
You can get 3/4 to 1/2 bushes from a good plumbing supplies. And if you want to use 22mm rad valves(expensive) you can get 22-15 internal reducers for the compression fittings
Use ptfe and a good jointing compound (jet blue from plumb centre).
Inhibitor is important to prevent the rads from sludging up too
thanks agian simonjohns, i know about the ptfe on the threads and to go 15 to 17 times around thread, what would you use the jointing compound for in this situation.
on top of the ptfe?
if you need any advice on growing veg i am quite good at it and would gladly oblige
of course i could tell you to "use a farmer, a real one would know what to do"
on top of the ptfe?
use the yellow gas ptfe it's much better
Reply to old school type radiator..fittings sizes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
Hullo everyone its a while since I posted on here basically because i have had no plumbing issues however I have one now. My son recently moved...
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one...
  • Locked
Hi, I am in need of an experienced plumber for the following jobs: bathroom: Remove exisiting toilet. Fix new toilet. Fix new wash basin and...
