Discuss old solid fuel Back Boiler leak? in the USA area at PlumbersForums.net
Hi everyone, im not sure if this is the right forum but here goes,
So i have noticed after getting my chimneys cleaned out that the soot from my kitchen chimney is damp and it looks like my old solid fuel back boiler has a leak of some kind. the boiler was put in when the house was built in 1981 so you could say its well past its prime. in the past few years i have never felt it was safe. The house i live in is very small and compact so heating is not an issue, i have decided though not to light the fire where the boiler is leaking for fear of it exploding! Ill eventually take it all out next year at some point anyway, i just have a question if anyone can help? My kithen fireplace that contains the old back boiler is directly behind my living room fireplace, (they are back to back) which i still want to use for lighting a fire, is there a risk in lighting the living room fireplace when both fireplaces are back to back? would the heat living room fire heat the back boiler in the Kitchen fireplace from the other side ??
any help with this is much appreciated
regards,
Seosamh.
Has the back Boiler been Isolated and drained from its water supply tank? I would advise this is done so the system is empty if you're using a open fire, we should be encouraging you to upgrade there are many electric panel type heaters that can possibly work for you. Kop
Reply to old solid fuel Back Boiler leak? in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
