Discuss old waterpipes and new toilet installation help needed in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
You will have to keep to a low level toilet and cistern
So you can’t type a reply using the box at the boot on if the last post then post reply ?
Reply to old waterpipes and new toilet installation help needed in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
