Discuss Outdoor stopcock leaking in the USA area at PlumbersForums.net
Just out of interest, let us all know if inside or outside their remit. When they come. To me looking at your photo it looks like it is on your drive?
Yep so the stopcock is on my drive but when there was no hesitation from TW to send out an engineer, who will be resolving the issue within 48 hours. I did also notice that on my plumbing and drainage insurance, it does say they do not cover external stopcocks as this is th responsibility of the water company.
Must all be on drives round where you are then. :) No cost to you then. If its been leaking a while you could ask for a rebate.
Hmm, I think there is a chance that TW will just install a new stopcock and meter at the property boundary and then ride off into the sunset leaving you to fix the problem.
Let's hope I'm wrong...
Don't worry, you are wrong as far as ownership is concerned, so the law is on the OP's side.
The first external stopcock and pipe leading to it are the property of the water company, if they are on private land. If the stopcock were on public land, the water board owns the stopcock and the pipe as far as the boundary.
If TW were to install an additional stopcock at the boundary, or in the public land outside, it would still own the pipework up to and including the existing stopcock. Since the OP does not own the existing stopcock, it is not his to maintain, and the ownership of the pipe would not suddenly change just because the water board has fitted an additional stopcock. In any case, cutting into an old pipe rather than replace an existing valve is hardly a shortcut, so I can't see TW even bothering to try this workaround.
What I'm not sure about is whether the water board is required to re-lay the block paving to the current standard, and I suspect the answer is no. If you're lucky, though, TW's plumber may be able to repair the existing without having to dig it out, as Moonlight has stated.
So I had the the TW engineer come out and do a few tests which confirmed there is a leak so told me this would need some digging up to get repaired and would take around 4-5 days. Luckily I'm not on a meter and there is no change in pressure at home so I hopefully shouldn't be impacted as much. I did ask the engineer I have concerns that a meter might get fitted and he assured me that would not be the case as its not compulsory for TW. He said it may water meters are only fitted as compulsory for new buildings.
My water company once did a compulsary meter fit down my mother's entire road as an experiment. We weren't forced to pay metered charges, but obviously I could read the meter and work out what the metered charge would be.
After seeing how little water she actually used, my mother decided to change to a meter and watched her bills go from about £350 a year to around £150 a year. I'm not quite sure what people have to do for a meter to be an expensive option!
How many people in your mother's household? I've been told by couple TW engineers that on average if you have less than 4 people in your house then a meter should be cheaper overall but anymore is when you start seeing the high prices. For me, I'm looking to start a family up and so I'd rather pay the extra now and be off a meter down the line (if I still have the option to).
In fairness, my mother's house was a three bedroom with only two of us living there at the time, so I suppose it depends on the circumstances. We were very lucky in that we had a meter we could read, so we knew exactly what our costs would be if we were to switch to metered.
By the way, Moonlight, what do you dislike about my post above?
Reply to Outdoor stopcock leaking in the USA area at PlumbersForums.net
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the...
Hi all, I have a query in relation to stopcock valves for the main cold water supply into the flat just before the water meter inside the flat...
2K
Building Description A new (23 years old) 1 story small block of 7 flats. water enters the building and distributed to each flat from a communal...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by...
TheCatWhoNeedsaHotShower
T
