Discuss Outlet size for a 3/4" Garden tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
GCM
I'm trying to replace an old outdoor tap that is connected to some MDPE piping (the house is built on an old road depot and it was an existing installation). It has a "Round Mixer Tap Connector" for the hose but it leaks like crazy and when I took the tap off to have a look, I was sure there wasn't a double check valve. The tap says BS1010 3/4" but that's only for the inlet; the outlet is something like 7/8".
The trouble is that while looking for a replacement, a lot of sites give me the impression that a 3/4" tap won't fit a hozelock type adapter, regular garden taps seem to have 1/2" inlets, and most suppliers don't specify an outlet size.
I was wondering if there is a standard corresponding tap outlet size (like how a 1/2" inlet tap usually has a 3/4" outlet/hose union)? Secondly, the tap is currently used with a sprinkler and I was wondering if the check valves, or if I were to try find an adapter to 1/2", would cause a significant decrease in the water pressure?
Your tap is perhaps a 3/4" tap. Most new standard outside taps are 1/2" inlet, but 3/4" outlet thread for standard Hozelock fittings and any other brands.
You can get adapters (usually plastic bushings) to change from your tap thread to the modern 3/4"
You can get 1/2" or 5/8" or 1" that all change you over to 3/4"
If your tap is 3/4" thread, then you need an 1" adapter available from some DIY kits
So a 3/4" tap is likely to have a 1" outlet? I shouldn't reuse the existing tap because it can't stop a backflow but it's a bit easier if I know a new tap's outlet will be 1".
So long as the sprinkler is an above ground type (i.e. not a pop-up) you should ensure that a double check valve is installed pryer to the new tap.
If you can get this inside your house to provide it with protection then that is the best option as required by the Water Regulations 1999 if it has to go outside as the tap is on a post it needs to be protected & insulated against frost damage.
Taps with the check valves built-in are for replacement purposes only I am afraid.
Reply to Outlet size for a 3/4" Garden tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi, I bought a Grohe kitchen tap to replace my existing one and have found that it comes with fixed flexi hoses that are 3/8" instead of the UK...
1K
