Discuss Outside tap soldering in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
JM1234
Hi all, keen DIYer here. Installing an outside tap and have tried soldering the joints leading from the 15mm copper pipe to the mains pipe. My question is a bit random but as I was soldering, the copper pipe going through the wall obviously got very hot, and got me thinking, could the heat conducted create a fire within the cavity wall? Something I hadn't considered and got me a bit concerned.
Nah I doubt the heat would. I'm always careful about naked flames going inwards where the hole is but I expect it would be incredibly hard to do on a masonry wall.
Thanks Fowler. I was concerned about the insulation as well as masonry, but from what I’ve read I think insulation is generally designed to be fire retardant
Ended up finishing the job with compression joints anyway. All nice and squeaky tight and I haven’t noticed leaking. Does anyone know if compression joints can just fail, or given the fact there’s no leaking am I safe to leave the water on?
Reply to Outside tap soldering in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
B
Hey Team Looking to fit an outside tap, gone to see what I'm working with under the sink and as you can see from the imagery I've got 2 Hose...
Deleted member 120897
