M
mcniven
***bria handyman your Probibly holding your rothy grips the wrong away as well these can cost vital seconds
Discuss Outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So because this other handyman takes 2 hours means we do?
I'd take double the time to lay a floor than a joiner would!
In all honesty tho its an hour to fit outside tap , 20 mins of work 40 mins drinking tea !
119 posts about an ootside tap? Is this what the forum is reduced too? Really you should all be posting about.....
..........The reason I don't use flexies is.......
Now that's a REAL forum topic. Amateurs the lot of ya. :jester:
And by the way I win. I can install mains water to a garden in 3 minutes. It's called a big hose from the kitchen sink.
Argument setteled i did one in 25 mins today
carpenter???
what era are we in 50 BC!!!!!
Carpenters as you call them in this day and age are either chippie's ,joiners or labourers
Yea, right.
Stand by, another Walter Mitty will be along in a minute to say he fitted one in five minutes.
:earmuffs:
posting about outside taps, it doesn't get any better than this. - heads towards fridge.
Sent from my iPad using Tapatalk HD
What is the problem, just because you can't do the job in 30 minutes then nobody can?
Another Walter Mitty...
Challenge - someone, anyone post a vidio of you doing an outside tap in 30 minutes or less and I will post a video of me walking on hot coals.
Bib tap
Wall mount
Hole drill
Lining
Copper pipe
Soldered joints
Double check valve
Isolation valve
Check for earth bonding
Clean up, etc, etc, etc.
Reply to Outside tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
