Discuss Overflow likely source? in the USA area at PlumbersForums.net
I have a constant overflow coming from the main tank in the loft. It builds from a trickle to a pour. The isolation valve on stopcock is off. The expansion from immersion heater hangs over the tank, but is dry. This tank is highest in loft, so only source must be mains coming back up through the bottom of the tank. Any ideas?
Have had iso valves in the off postion let water bye. What sort of valve is it, wheeled gate valve, lever turn valve and how old if known.
It's only a small 15mm screwdriver turn valve, but I can confirm no water is getting in that way. Not a drip from the ballcock while tank level is still rising. It must be coming up the downpipes, and it must be coming in at mains pressure. Could a mixer tap or washing machine be passing from cold mains to hot gravity?
Reply to Overflow likely source? in the USA area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi all, looking for some advice about an overflowing cold water tank. Each morning the tank has continued filling up, so by the morning we have...
2K
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached...
2K
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
J
I can't get a consensus on this from four plumbers that have visited. We've been using the system with no prpblems for 7 years - but the cylinder...
