Discuss Paint advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
I need to paint a masonry square of about 8" square only
I need it to be stipples to match in a best it can
Can I mix paint with filler to try to do it?
Textured paint ain't prickly enough
Paint shop would have been a good place to ask, as some of the staff can be very knowledgable. I suspect if you add a little dry clean fine sand to the masonry paint it will make it textured. - That is, stir it into it before you paint!
Reply to Paint advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
