Discuss Painted soil and vent bits identification help needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Want to replace WC. Want to replace pan con and new WC waste may be slightly higher/lower.
Never installed soil and vent so am guessing a bit here.
Purple line fitting: regular pan conncector
Red arrows: 110 elbow with top end being plain and bottom end having rubber seal.
Inside elbow and also inside blue line fitting: Piece of 110mm pipe? Blue line piece some sort of spigot coupler?
Yellow line fitting:?
I don't have any 110 pipe or fittings kicking round and would prefer to avoid getting any if unecessary. I want to pull free what I need to pull free and put in a new pan con while being able to allow for new connection being further out from/further in toward wall and/or higher up or down.
Where should I be trying to separate and what bits should I be armed with?
It should pull out from your blue socket. The new pan will probably sit closer, so you will need a short ( 2 1/2") piece of soil pipe and a bent pan connector.
If your new pan is the same, it will connect back in to the existing. Most pan drain connections are the same height from the floor, about 7 1/2".
Reply to Painted soil and vent bits identification help needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Hello. This is my first ever post asking for help. I had a bathroom renovation done early this year which I did myself. I wanted to have a low...
I wonder if anyone is able to help with advice on this. We have fitted a new toilet and 6 litre cistern .. it flushes .. but not as efficiently as...
2K
I'm trying to pull a Polypipe SA62B access plug and cap out of the soil vent branch (which I think is a Floplast SP190). It's a bit of a cramped...
2K
