Discuss part 2 ball valve in loft in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
I'm off to fix an overflowing loft tank this week. I'll be taking a new Part 2 FOV with me.
Just wondering... would you bother fiddling round to replace the diaphram/washer/etc, or just cut to the chase and install a new FOV? After all, they're so cheap.
Thanks again for your advice,
Jennie
Usually I'd just replace it, although sometimes it easier to split the old one inside the tank and put a new front on it.
If the old valve outwardly looks in good order I would consider just changing the washer (old type or part 2). The old hp ball valves often are better quality than the new scrap valves & worth fixing if it's only a wee washer.
In fairness though, if you tell a customer you fitted a brand new ballvalve, then they will think it worth more than a repair, plus you could charge a couple pounds extra for the valves cost.
And sit there for an hr to get your moneys worth rofl
One other point that may sway your decision - your scrap brass pile will get heavier if you replace the ball valve! :smile:
Reply to part 2 ball valve in loft in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi, one of the two hooks on my toilet Torbeck fill valve has broken, and so the float can't connect. I've bought a new fill valve, however it's...
Deleted member 120897
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
