Discuss persnalised gas safe pads - best place to get them in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beesley121
hi guys,
I after some personalised gas safe pads - can anyone recommend the best place to get them
Your local printshop can make these up with your company name, logo and any other details pre-printed on ncr sets in pads.
I buy NCR paper and print my own. Made up a form using word.
I cant be bothered, just use a self inking stamp with my details :)
Hey guy. Is that for android or are u apple ?
Just trying this app called icertifi. Pretty good!! All Certs warning notices
The problem with warning notices though is what about leaving one at the property? Unless you have a printer in the van then it's going to take a day or 2 to get the certificate to the property when technically you should leave them on the property.
Reply to persnalised gas safe pads - best place to get them in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
