Discuss pex expansion looping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mr Wilson
greetings...
just a quick question
im putting pex into a chased brick wall to be rendered over and was wondering if there will be any expansion issues as i read pex can expand up to 15% and placing an expansion loop in stud walls is standard
My pex is in insulated but ive no way to put in a loop between rads whats folks solution for this or better whats the longest distance of pex pipe before a loop is necessary.
any thoughts are appreciated
not heard that one, but best to leave room for pipe movement as per normal
Not an issue in stud partitions but could be on a finished surface chased solid wall. By being inside insulation tho it is not a problem as the pipe will expand back to the void it is fed from.
cheers tamz ... so i should make sure that my anchor points provide some movement for the pex. i was placing anchor points every meter or so.
so how will that work between rads as its basically a daisy chain with a length of pex and T adapters providing flow to and from rads.will there be any push and pull on T adapters ... actually come to think of it theres only 1 length of about 5m between rads the rest are all under 2 meters so expansion shouldn't be an issue.
cheers
Reply to pex expansion looping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
