Discuss Pipe Detector for concrete floors in the Plumbing Tools area at PlumbersForums.net
Jock Spanners
Evening All,
I've just had a mare of a day digging up a kitchen floor trying to re-route pipes. Can anyone recommend some kind of pipe detector that will detect pipes in concrete?
Jock
If the existing pipes are part of a working heating system then a thermal camera is probably your best bet, and has the advantage of working with plastic pipes. I'd recommend hiring one to get some experience before deciding whether to buy. Good ones, e.g. FLIR, are quite expensive and unless you do quite a lot of this sort of work and and/or leak-finding you may not break-even on ownership.
Reply to Pipe Detector for concrete floors in the Plumbing Tools area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
