Discuss Pipe lagging for radiator pipes set in plaster in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My plumber chased some radiator pipes into my masonry wall and has left it to me to cover up - which I will do with plaster filler.
However - he hasn't put any protective cover on the pipes.
He suggested I get denso tape and wrap it round the copper pipes - but denso tape has a melt point of about 60 degrees celcius - so not really suitable around hot radiator pipes.
Can anyone advise on what type of tape or lagging I need to put around the copper pipes before plastering over?
Thanks in advance.
Waterproof duct tape I use
not sure denso or waterproof duct tape can be used around really hot copper pipes.
how about pipe lagging? Is this for hot radiator pipes?
Economy Pipe Insulation 15mm x 13mm x 1m
Chase would end up too deep as it's 13+15+13
So that's close to 1 3/4" deep
And I haven't seen it peal when hot
Do you know any thinner alternatives to pipe insulation? and suitable for hot pipes?
Other than 9mm no 10mm pipework your stuck as they don't make insulation for
Not the worst job to just do with sheet of polythene cut into strips of 4" wide and wrapped up like a bandage with double wrap (overlap) and electrical tape to secure the ends. Ordinary dry wall will not do pipes any harm then and it allows slight expansion movement
Won't they sweat ?
Won't they sweat ?
Doesn't seem to do the pipes any harm.
I wouldn't advise anyone doing it that method in a wall that tends to be always damp, but on a wall that is to dry out it just keeps the cement etc from contacting the copper and allows the pipe lengthways expansion movement.
I much prefer pipes inside round conduit where possible though
Depends on the depth but with mimimum cover i would use aluminium foil tape , armaflex do waterproof insulation but i am guessing it would be to thick for this job . cheers kop
I did a bit of research and armaflex or Reemo do a thin protective insulation tape. Both perform at high temperatures. Not sure if they are suitable for being buried in wet plaster....
https://www.amazon.co.uk/gp/product/B074QSDTRM/ref=ox_sc_act_title_1?smid=APCCEBV4WO30B&psc=1
https://www.amazon.co.uk/gp/product/B0069R66BA/ref=ox_sc_act_title_2?smid=A1QKFATOCKF26&psc=1
Yes there both fine in plaster
Reply to Pipe lagging for radiator pipes set in plaster in the Plumbing Jobs | The Job-board area at PlumbersForums.net
