Discuss Pipe reamer worth the effort? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have lashed out a couple of quid to buy a pipe reamer. Knew it was not going to be a masterpiece in engineering. Are they worth the effort, well these cheap ones anyway, seems to "ream" off very little.
That is what they do, a little at a time, its not a drill!
Bogart, I've used the Kopex ones. They're OK but its just more things to lug about. Particularly useful if using a pipe expander as they remove a good bit of the "rounding over" you get from a pipe slice.
I find I use the old red plastic Rothenberger type more than the Kopex because they are lighter and cover more pipe sizes.
Reply to Pipe reamer worth the effort? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
