Discuss Pipe size on radiator any help would be nice in the DIY Plumbing Forum area at PlumbersForums.net
Hi, does anyone know what size pipe this is?
And what elbow I would need for a like for like swap?
10mm pvc pipe, going to a 15mm x 10mm reducing elbow. If you’re swapping the valve, then keep the elbow, nut and olive on, and just changeover the valve, threads should marry up.
Reply to Pipe size on radiator any help would be nice in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
