Discuss Pipe Wrench in the Plumbing Jobs | The Job-board area at PlumbersForums.net
depends what you use it for and how often, pipe wrench as in a stilson?
i have used many and some cheap ones are good. the teeth all where down eventually and slip off.
What are you thinking of using them for?
Rigid are best quality and allys are a lot easier to handle but not necessary for general plumbing.
I barely ever use em - not on brass as it rips it to hell . . .
If you must get a stilson, then get it cheap.
I have however got 4-5 spanners and grips of various sizes . . .
Hello
Can anyone advise be on what pipe wrench to buy, I have decided on Rigid but cannot determine what model to go for. Heavy Duty or Aluminium, what do you guys think/recommend? 18".
Link> Wrenches - RIDGID Professional Tools
Sorry if I'm sounding rude. I feel if your having to ask what type of tools to buy to carry out plumbing work :confused: you shoud'nt be touching any kind of plumbing at all. :eek:
I'm not a tradesman. I have a couple of pipe wrenches but always tend to use one of 3 sizes of adjustable spanners plus a few open enders. The large stilsons come out for large long fixed valves.
I wouldn't be without curved jaw molegrips though. Never use them on nuts but invaluable for holding the body of a compression joint where there is not enough shoulder space to get two hands to the job.
welcome ConorM8350 it all depends on what you will use them on they are really designed for pipe fitting that said plenty of plumbers use them daily.In my toolbox I carry a pair of record size eights but from my earlier days I have various sizes from size 8`s all the way up to size 48`s all made by record.Rigid make some cracking bits of kit .Aluminium are good but do really want to carry them around if you can use something smaller .Maybe go to a good toolshop and check out your options.Good luck:)regards turnpin
i do nearly all pipework using 10" grips and 8" wide jaw shifting spanner, plenty other great tools too but thats what you can take to most jobs in one hand with couple screwdrivers. i have few sizes of stilsons but have a 14" in case
Reply to Pipe Wrench in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
  • Locked
Due to start training as a plumber and want to start building my tools up now to save me spending in bulk at a later date. I appreciate it does...
17K
Z
  • Locked
Hi Folks, Do any of you have any tips or know of any tools that can make 15mm/22mm pipes round again at the end that will fit into a compression...
18K
JJayMan
J
E
  • Locked
My house was built in 1964 and I assume all piping was then imperial. As part of the work I am undertaking I am replacing the WC. The existing...
6K
easyt
E
  • Locked
whats the best tool for cutting bath panels had a job on yesterday took me 3 hours to cut and fit front and end panels was tricky though
15K
T
R
  • Locked
help in kickstarting the grey cells please. got a std rad to be switched for a chrome towel rad and the tails are 4'' too wide. i cant really...
4K
Billy Bob Bob
