C
cascas
What sort of tape should be used when a pipe is chased into a wall and plastered over. Denso, seems a little extreme, is something like pvc electrical tape ok, or is there something better
Discuss pipes in walls - protect from corrosion, which tape? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
i use grey gas tape mate, deffinatly the best stuff to use, can be a bit fiddely to put on after the pipes r in the wall so try and tape them up b4 u connect them up!
Reply to pipes in walls - protect from corrosion, which tape? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
