Discuss Pipes through boards thoughts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
10mm pipes for radiator going to underfloor, acceptable or not?
Not sure what the beef is with it? Is it because there is more than one hole and the sawdust debris being left there?
As always I fear there is more to this question.
Was it case of replacing radiators?
No real "beef" it's just the hole is fraction larger than the pipe, thought you might need it a bit bigger for expansion?
Are you relaying carpet? If so I wouldn’t worry. By the look of it the job isn’t finished yet anyway based on the woodshavings still on the floor
I wouldn’t worry about the holes. Those reducers are naff but I’d be hacked off that they just lay carpet over rubbish
Reply to Pipes through boards thoughts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Sonya K
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
