Discuss Plumbing a washing machine/ dishwasher - With not enough outlets? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
(I live in the UK so if supplying products please sugest UK items - many thanks)
I need some advice on how to fit a Washing machine/Dishwasher. Any feedback/ideas would me much appreciated.
Currently the sink is set up with one of these dual sink wash traps (see image or link at the bottom of the page). The trap is then connected to some floplast waste pipes and 90* bend sections.
The issue I have encountered is that all my dual sink wash outlets are full. For some unknown reason the boiler waste is connected to one of the outlets and a washing machine is connected to the other.
Unfortunately the landlord isn't very helpful with the situation.
If this was my house I would probably drill an additional hole through the wall for the boiler waste, but alas it's not my house.
So to reiterate my question is there any way of having three of these outlet.
Either through adding parts to the sink sockets.
Or adding parts to the floplast waste pipes (e.g replacing the 90* with a Tee section).
Or should I give up and argue with the landlord about the boiler waste being connected here so that I can fit my kitchen appliances.
Kind Regards,
Adam
https://media.NoLinkingToThis/is/image//ae235?src=ae235/33137_P&$prodImageMedium$https://community.NoLinkingToThis/attachments/upload_2019-8-31_22-30-25-png.33183/
FloPlast Dual Sink & Wash Trap White 40mm
Reply to Plumbing a washing machine/ dishwasher - With not enough outlets? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
I have an ideal vogue max S18 boiler and Iā€™m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler pump menu for either 70% or 100%, so, is the pump set at either one of two fixed speed percentages or does the pump actually vary speed, (modulate)...
