Discuss Portfolio template for gas exams and gas safe register in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dan_the_plumber
Hello all.
Just wondered if anyone has a good template so i can log my gas experience with a view to sitting my exams and then applying to the gas safe register?
Thanks very much
Dan :)
i think it's better to register with a training provider and use their portfolio. each training centre uses their own and probably won't accept an outside one imho.
you will need to complete your portfolio with a training provider before you do your ACS exams with them, so better to sort where you will do the exams with then ask them what they use and ask for a blank template to start recordig your work as this will save you doing everything twice
Hello all.
Thanks very much
Dan :)
are you a time served plumber? the reason i ask is that depending on your actual qualifications as oppossed to your experience this will determine what route you need to take to get your ACS
I'm in college and everything but kind of fast tracking my quals at the same time...
thanks RedSaw for that template i'll check it out now
might come down to asking lecturers but i'll certainly check this one out...Ta
Dan
Reply to Portfolio template for gas exams and gas safe register in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
