Discuss Potterton Gold Combi 33 HE A-Fault NO hot water or heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Hardy1
Hi there guys..just been called out to a Potterton gold combi 33 he.. no heating or hot water....pump- fan then fans goes off.. and pump is just running :S..no ignition??..checked thermistors etc...any thoughts and any help..many thanks...Hardy1
did you check the aps for proving
Does it ignite? If not as above check aps first
E133-fault code(dancin plumba)... yep checked all gas pressures TT passed no drop.. 22mbar standing pressure at meter..21.5 mbar standing pressure at appliance literally less then a 2m run from gas meter.. any help guys?.. cheers again.
nope no spark.. pump-fan. fan cuts off...i done a bit of research online and suming about spark electrodes are faulty..
link to mi's [DLMURL]http://www.potterton.co.uk/docs/Pot_gold_Combi18HEA_instal_sept_10p.pdf[/DLMURL]
fault section 'H'
thought so was thinking spark gap or electrode.. ill get back to it..cheers dancin plumba.
checked..the boiler was installed 2 years ago..been working fine since...cheers.
Is gas valve opening ? is fan running at full speed ? may come down to PCB !
Reply to Potterton Gold Combi 33 HE A-Fault NO hot water or heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
