Discuss Potterton Gold HE problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BrianS
Hi
I'm new to the forum but looking at the excellent content I thought it might be a good place to post my problem.
I have a problem with a Potterton Gold HE 24. It started with loud banging caused by the boiler not directing the supply to the rads, causing it to boil up and release pressure from the release valve also code E110 popped up. Pump appears tbe running okay and when it does fire up rads warm quickly but cool just as quick
I assumed at first that it might be a blocked heat exchanger therefore removed and gave it a good clean. After re-installing it I still had the problem but bled the system a few times and eventually got it going for the temp to rise, run for a short time then cut out and after a few mins cut back in again. This warmed up some rads but not the furthest away ones. This continued for a couple of hours and then it went back to boiling and pressure releasing. I dismantled the three way divertor valve switch (not the part inside the valve) to see if any cogs/springs had broken but all okay.
Im now thinking that it might be a thermostat problem or possibly PCB. Suggestions most welcome thanks
Whilst looking at the excellent content you forgot the rules.
Reply to Potterton Gold HE problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
E
The boiler runs may be 1 or 2 days before erroring. The problem started 3 months ago. The boiler would run blue light on at front an center of...
Deleted member 120897
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi. I have a hot water high pressure problem that my heating engineer (and other engineers that he has spoken to) cannot fix. I’m hoping someone...
1K
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
