Discuss Potterton Performa 24i HE DHW Activation Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
zillaplumb
Hi All,
Have come across a potterton performa 24i he that the customer has complain does not activate when the hot outlet is opened, have found the cause is the dhw differential pressure valve has a temperamental pin which doesn't come out when it should in turn not activating microswitch. I assume this is due to a faulty diaphragm within the valve, but am not sure whether the pin and spring assembly could be damaged also. Can these components be obtained seperately without having to replace whole valve body, elderly customer is unable to afford costly repairs. Thanks Guys
Just replace diagram,that will do it,you can get all the parts you mention though
Thanks went ahead with my gut instincts and replaced diaphram before I could read your but thanks sharing your knowledge :). have a new problem now need to replace the sensor tubes that come from the cw inlet valve to the diff pressure valve leaking like a sieve :s
All the best!!
thats because the tiny washers have broken go on parts arena for the part numbers ask your coustomer was it whineing before it broke you may need this //www.abcotuk.co.uk/[/url] look at the baxi instant valve
wasnt whining according to customer ,sourced washers tiny little 6mm o-rings bloody hard to find nobody knew what i was on about also source new negative and postive pressure pipes and replaced, all working fine customer has hot water again many thanks for advice.
Hi lads, i am in need of these parts, would u know of a place i could get them today
Reply to Potterton Performa 24i HE DHW Activation Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I see this question has been asked before but I haven't found a full answer yet, so hoping someone can help. I have a Potterton Performa...
1K
  • Locked
Hello All Its me again with another question about my potterton combi boiler. Sitting indoors the other night sweating my n*ts off thinking...
2K
W
  • Locked
I have a Potterton Performa System 24HE boiler. It is configured in a typical S-plan with 2 external 2-port zone valves (V4043H) along with hot...
3K
Dotty
  • Locked
i have a potterton performa 30he combi boiler,and it has a problem,it keeps coming up with a pump/water pressure warning,if the contact switch...
8K
M
  • Locked
I have a problem with a Baxi Combi Instant 105 HE. Initially when i turned the hot tap on the boiler didn't do anything but when i pushed the...
3K
markofled
M
