Discuss potterton power max he pressure vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jeff123
Hi all, I'm new here so hear goes.
I have a potterton power max he, I've had some Ch pressure issues which I traced to a faulty pressure relief valve
Which is now on order but when I went to check the pressure vessel's the external one was ok but when I put the
Pump/gauge on the primary one, water came out and with a small pump I could hear bubbles.
So my question is
A, do I need to change the primary vessel or will the external one do the job
B, is it this that damaged the PRV
One other thing, with the boiler off its at 1.5bar and running it climbs to 2.3bar
Are these differences because of the primary vessel?
Thanks Jeff
Reply to potterton power max he pressure vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
