Discuss Potterton Powermax HE: Only generates one showers worth of hotwater at a time in the Central Heating Forum area at PlumbersForums.net
I've just moved into a property with a Powermax HE boiler, and it only seems to produce one showers worth of hot water at a time. I then have to boost it for an hour before we can get another shower.
The hot water is set to come on from 13:00 to 17:00 every day.
Its controlled by a Hive system.
The previous owner told me it had its PCB changed last year.
I've lived in a nearby property with exactly the same boiler about eight years ago and I cant recall having any issues with it.
How can I get it to generate and store more hot water? Is this a common/known issue?
I think these came in three sizes (different size integral HW cylinder), do you know which size you've got? Maybe the one at your other place was bigger. Do you live in a hard water area? Maybe the cylinder is all furred up?
Reply to Potterton Powermax HE: Only generates one showers worth of hotwater at a time in the Central Heating Forum area at PlumbersForums.net
I have recently fitted a thermostatic external mixer shower in my bathroom. The problem is that when it is set to the highest possible temperature...
2K
Just had a new boiler installed and looking for some efficiency advice, please. We have always set the Heating to run from 6:30 until 21:00 via...
Hi there, We have a standard gravitational system at home and a Salamander pump CT force 30pt is part of the hot water system for the 2nd floor...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
Recently had boiler issues heat exchanger was replaced but water would still go Cold Randomly especially in the shower. Engineer says Combi...
3K
