phozy888
Hi Guys,
my boiler has started to switch itself off after a few minutes so I took the fron cover off to check the diagnostics lights. Its flashing like this : FLASH - OFF -ON.
Having read the manual it shows a overheating lockout - The manual shows 3 possible faults.
1 - The PCB
2 - Red Thermistor
3 - Thermo Stat
Which would be the likely cause ? I was just going to order and replace 2-3 hoping it would fix it as they parts are relatively cheap. Or could it be another issue ?
Thanks !!
1 - The PCB
2 - Red Thermistor
3 - Thermo Stat
Thanks !!
