Discuss Pound shop bargain? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
emergencyman
So tonight the wife is painting with a small brush and asks me if I have any brush cleaner.
I say no, but have Polypipe cleaner and go get her that, tell her to take it easy as its £8 a 250ml tub.
Wife says I've been robbed, its the same stuff as her nail varnish remover called Acetone and she gets hers from the £1 shop in a 400ml tub.
Is it the same stuff? If so get to the pound shop.
I don't know if it's the same stuff, but you are definitely paying too much for your cf250
I have never seen anyone clean plastic pipe before glueing it... I never have and have never had a glued joint leak...?
I think your right Ray. A Google search shows it can be had from around a fiver. TBH not sure what I paid for mine, it was jut a guess.
Only reason that I use it is that a lot of my work is joining onto old stuff.
I used to use it years ago when doing sewage pumping pipework that was under pressure - never bothered on waste pipes no pressure
Acetone does wonders on most plastics and stainless also removes wet exp foam
used to use that stuff by the 5 gallon at a time, burns well...but the price shot up.
btw, it melts plastic if in contact with it too long, try it in a plastic cup for a day.lol
or for the more adventurous, try a bit in your coffee ?:?)
Same here. Used it on 4 inch plastic for pressurised pipework on reverse osmosis plants.
On domestics just use abrasive strip to scruff up the surface.
Same here. If the plastic is dirty I give a good clean with emery cloth.
I remember using methyl ethyl ketone when I was in industry. That's nasty stuff and will strip paint off, but if you've tried everything else, it often works as a last resort.
For degreasing in the workshop I usually use isopropyl alcohol.
I'd like to know what would work in place of the contact paste for my rothenberger eco pipe freezer. It looks and feels like moisturiser. It's odourless. The stuff I buy is only available from a few stockists and so they take the pith on price. I bet you could get like a mayo sized jar of some sort of tesco on brand woman's general use goo and it would work. Might have a test. If I can be arsed. Which I almost certainly cannot.
I have a freeze master and have not once used the paste.
A wet tissue wrapped round the pipe then freeze, it's just so you have no air gap between the clamps and pipe.
works every time
the freezemaster comes with paste though?
so you think it's JUST a ploy to make money? seems elaborate. might as well include a hat you HAVE to wear. seems like a risky business freezing anyway. i'd worry it works fine 99 times out of 100 but has that 1% extra risk of going whoooooshh.
Lol mine didn't come with a hat. I froze a lead mains today to move the mains stop tap, it's the no plan B that worries me.
if it goes wrong I can't turn The water off... But I could smash the lead over, the hat would keep my hair dry.
good point on no plan b. if there was a good plan b you'd be doing that instead of freezing. brown trouser time.
worst thing is when customer tries to talk to you in the middle of it once you've got an open live pipe.
Any pics of your freeze machine in action would be helpful. I've got a freezemaster but it looks right pain to clamp to pipes. What sort of clamps do you use?
I've had mine a while now but yet to use it. It seems easier to snatch or stick a valve on. I've stuck it in the shed
The last time I froze a main as I was putting the stop tap head back in, the ice plug went just as i was tightening it in. Never again! It's just not worth it.
Was this the freeze can sprays or a proper freeze machine... The machines claim to freeze the pipe indefinitely....
Reply to Pound shop bargain? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
