Discuss power of a burst main. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A guy I work with his bro in law just got a part time job after quite a while out of work the main part of the work was carried out in the basement workshop and a water main burst flooding out all the local shops but many had basement workshops so bang went his new job for the time being claims are still being processed with Thames water for damages ......can happen to anyone at anytime......regards Turnpin
some power, the house it was spraying at had a load of road fly through the bedroom window apparently.
Reply to power of a burst main. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A gardener/landscaping friend of mine is going to install an irrigation system in a customer's garden. He asked me to pop around and measure the pressures and flowrates...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains pressure from small hole/crack The outside of pipe (measured with veneer caliper) at 23.5mm Pipe Runs under drive, along side of property and looks to go...
I have a seemingly impossible problem. I am not a plumber but I can at least understand some of it. We have just had the Water Board inspector here and even he went away flummoxed. OK ....we have a stopcock under the sink that is stuck open - no amount of force will turn it. We need to turn...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
