Discuss Press fit plastic pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MOSSEP
I've got to move a radiator in a garden centre that's been installed using press fit fittings, not sure what they are or exactly what pipe or fittings have been used it is but it looks about 15mm to the naked eye. Any idea if Im likely to be able to use compression fittings or speed fit on the pipe to extend it? I use press fit copper all the time but don't have anything for plastics so want to turn up with a few options incase the need arises!
Cheers
Martin
If it’s Malcolm most I’ve come across is 16mm, can get a compression fitting to get you back to 15mm copper.
Malcolm = mclp!
Or mlcp or whatever it is
Need these 16-15mm compression ,
Reply to Press fit plastic pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Sonya K
