Discuss Pressure dropping in boiler in the USA area at PlumbersForums.net
Hi guys,
Just need a bit of advice, i have a Valiant boiler fitted and over the last few years the pressure has been dropping intermittently, it can go months with no problems then i switch the heating on or turn a hot tap on to find there is no pressure in the boiler and i have to top it up again before it will fire up, over the last few days it is happening everyday, i put the heating on theres no heat, top the boiler up and it works, once the heating switches off the pressure drops and im back to square one.
I have looked over every radiator, trv's, bleed valves and any pipework i can see and there is no leaks that are visable , i had an engineer out about a year ago when it was doing the same thing who said these systems have a known fault with the expansion vessels, he opened up the boiler pumped up the vessle with a pump and the boiler seemed to be ok up until a few weeks ago when it started doing it again.
What i really wanted to know is before i start pulling the floor up to look for a leak is there anything else i can try? Does anyone know if a faulty expansion vessel in the boiler would cause this problem?
Any help would be greatly appeciated.
Thanks in advance
Reply to Pressure dropping in boiler in the USA area at PlumbersForums.net
PSxxxxxx
