Discuss Pressure problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, wondering if anyone has had this issue before;
i have just just put an external expansion vessel onto a main combi 30he as the old one had perished. However after about a day the pressure is dissing again above three bar. The filling loop is not passing. My only other thought is there is a perforation in the plate to plate heat ex which is passing water through to the boiler. To make it more awkward I can't isolate the hot water to test this due to the age of the customers. Before I replace the plate to plate, I was wondering if anyone had this issue before.
many thanks
Fella you need to read the forum rules as we will not give any advice relating to the internals of boilers to those who have not proven their Gas Safe credentials. Regarding the external expansion vessel what pressure did you set that to
Yes system was cold, I then ran the system up to temperature and it cut off before it got to 2 bar after I had finished the work. However, a day later **** getting over 3 bar again. There must be a small leak into the system but not through the filling loop. Was wondering if anyone had the plate to ate passing before.
Was it cold or depressurised is what I'm saying. Do as per the link mate say a few hellos comment on a couple of threads then just send your gas safe details to one of the moderators and we will be able to discuss in more depth
Will do at some point when I have time. Expansion vessel is pressurised at 1 bar when the system was empty. So it was cold. Thanks for your help but the problems not with the new expansion vessel. There is water passing into the system somewhere.
That's fine buddy I only ask because I know these things sometimes get missed when we rush at this time of year. I'm afraid that nobody will offer any advice regarding your theory until you are part of our gas safe only forum. I am sure you can appreciate it from a safety perspective
Reply to Pressure problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least three times a day. Trying to eliminate what the cause could be. Appreciate that it could be a leak somewhere, but looking to tackle one issue at a...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn back and it repeats itself. had boiler checked and told it was the expansion vessel. Had the expansion vessel drained and recharged. plumber told me...
Hi I have a baxi duotec combi boiler that every day or other day needs topping up as pressure drops below 0.5bar. When fired up it can reach OVER 2.5bar also whilst running CH. Is this more than likely a flat Expansion Vessel that needs inflating or could there be other possible causes if...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from the loft water reservoir tank (which also feeds the cold water taps in the bathroom & the WC cistern). There is an expansion vessel attached to this...
