Currently reading:
Pressure test Gauges
Discuss Pressure test Gauges in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DustyM
Gents et al,
Can anyone recommend a good set of test gauges? I'm trawling the net but cannot find anything reasonably priced (although I'll admit to being a Yorkshireman and thus reluctant to part with hard earned cash). Thanks!
Hmmmmm, ok, it might not be grammatically perfect, and the 'although' may confuse.........I'll try harder next time. In short - I'm looking for a not too expensive set of pressure test gauges.....advice, direction welcomed.
Sorry, figured seen as I was on the oil and solid fuel forum, it would be understood! Oil pressure test gauges for boiler servicing and commissioning.
my fault guys - anyway, if anyone can recommend I'd be grateful - thanks!
Oops..I just check new posts and don't really check what section posts are in..Sorry Dusty..Can't you use your analyzer?
My analyser doesn't measure fluid pressures (I don't think), will require oil pressure gauges.
Reply to Pressure test Gauges in the Plumbing Jobs | The Job-board area at PlumbersForums.net
