Discuss Pressure test on an existing system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mag71
Hi I will be replacing a leaking elbow on an existing dhw system soon, just wanted to find out if pressure testing is mandatory after repairs , and will all the taps need to be isolated . There are isolation valves from calorific flow return but can't see any in taps . I have only dealt with new installs to date so not to sure requirements of pressure testing existing system . Thanks for any input
No not normally, but if specd do it
if it just making a repair and the original system has held up fine before you begin, i would just fill up and check the fitting knowing the quickest way to drain down again before you begin to fill.
Reply to Pressure test on an existing system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
