Discuss Pressure v volume - the old chesnut in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Centralheatking
I cant remember the right answer - cause I am am an old ish F...
So we need to replace an old domestic water main for one of our regulars who has
moved hse. There r 3 adults all with 1 with their own sep facilities.
The 3 bed hse has already a new vaillant 730plus with the hot water storage bit but is a combi.
1 electric shower, bath (never used) but with combi hot water shower, usual kitchen + appliances
d/stairs bog and basin.
What i meant is will it be better to put in eg
50mm pipe to get more volume flowin ?
Thanks to replies so far - if ur pipe is in west lancs we will
buy lenghts of 25m aND fittings f cash
centralheatking
They are gettin 7-9 litres per min at best but it can dip. utility has tested ? the meter and quoted
the usual 11 litres stuff.
So the lead main is to be replaced but do we put in 25mm dia blue or wider ? pro and cons
on a postcard ...............I know they r tryin to get a quart out of a pint pot but
What does the collective wisdom consider ?
centralheatking
I'd put in 25mm simply because it isn't much dearer than 20mm and would offer less resistance to the flow.
GOIN 4 32MM PIPE AS NOBODY HAD ANY ADVICE
centralheatking
you dont want to oversize the main as this can cause problems also with legionnela i believe
Reply to Pressure v volume - the old chesnut in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Any help, advice or personal experience appreciated. We are supplied by a lead pipe but on a shared supply. I am about house 4 out of a run...
3K
U
  • Locked
Hi everyone - wondering if anyone can offer words of wisdom. I have a problem with the hot water supply to my shower. Its a bath mixer tap...
6K
K
  • Locked
5K
K
J
  • Locked
Year on year I have a problem with the central heating at home, it often catches us out right when you don't want it to (coldest weather)...
1K
Dotty
C
  • Locked
Hi - can you help? We have 2 Crosswater Logic 1500 showers, fed by an Ideal+ 40 Combi boiler. These were newly installed 2 years ago - all fine...
7K
