Discuss Pressure valve on top of hot water cylinder.........Good idea????? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
monkeymanal
Good afternoon folks. I wonder if any of you can offer some advice....
I have a hot water cylinder with a pressure reducing valve on top. Yesterday morning it let go in spectacular fashion flooding my downstairs. Having got a local engineer out who i believe seems to know his stuff and doesn't talk BS, he removed the valve and bypassed with a straight pipe.
Problem cured obviously, but his opinion was that it didn't need to be fitted in the first instance and secondly, if you did want to fit one, directly on top of the cylinder is a no no due to heat fluctuation.
The valve eventually let go through the rubber diaphragm and plastic outer.
Id really like some thoughts on whether it should have been fitted in the first place.
NB its around 4 years old in a new build.
Thanks in advance
Alistair
If it's the combination pressure reducing valve he has removed! This is dangerous, as he has removed the safety valve also.
Get rid of your "mate", he has done you no favours! Get a local g3 registered installer to replace the valve for the manufacturers part.
:nono:ell he took it off, SORT IT ASAP !!
Ok, he wasnt a mate or anyhting, he is a fully qualified by the book engineer. The cylinder is a Santon Premier Plus PP250B.
Ive also attached a pic of the valve prior to removal.
Thoughts and opinions still very much welcomed.
Ta
redir
turn it off immediately ​and get a G3 qualified engineer round sharpish to sort it out
No picture pal , just thank yourself lucky you posted on here , now turn your hot water and stop tap off
He's not just bypassed the PRV and safety setup on an unvented has he???
Reply to Pressure valve on top of hot water cylinder.........Good idea????? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all. This ‘valve’ is at the bottom of our domestic hot water cylinder. Anyone have any idea what it is please? It must’ve been there for many...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
1K
